Stop the Switch server before upgrading
Before installing a new version of Switch, make sure that Switch is not running, including the Switch server. If you're not sure whether the Switch server is running or not, launch the Switch designer in the regular way and quit it again. If there are any active flows, Switch will present a dialog with the option to stop the server.
If you were running the previous version of Switch as a Windows service, you may have to repeat the setup procedure after installing the upgrade.
