When you launch the Switch designer it displays its main window, called the workspace, shown here in its default configuration (design view):
The toolbar is the strip at the top of the workspace offering a number of tool buttons.
See Toolbar for more details.
The workspace contains a number of panes which can be manipulated as distinct entities (show, hide, resize, move, ...). Examples include the flows pane, the elements pane, and the properties pane.
The central area that displays a flow design is called the canvas; it is a special pane because it has no title bar and it can't be moved from its central position.
One or more panes (optionally including the canvas) combine to make up a workspace configuration called a view. The currently displayed view is selected by pressing one of the buttons in the leftmost section of the toolbar.
The workspace offers a number of panes that are displayed in a number of pre-configured views. Each of the views can be configured at will to display an arbitrary combination of panes. The contents of a pane persists across views (i.e. the different views display the same instance of the pane rather than different copies).
Panes can be shown or hidden by choosing the corresponding item in the menu. Panes can be resized by dragging the separators between them, they can be rearranged next to one another or overlaid as tabs by dragging their title bar, and they can be undocked as a floating pane. All configuration settings are persistent across sessions.
The currently displayed view can be returned to its pre-configured settings by selecting .
The workspace offers the following views. The intended function is only a recommendation, since the user can re-configure the views at will.
Tool button |
View name |
Intended function |
Design |
Design a flow |
Test |
Test-run a flow |
Run |
Run a flow in production |
Messages |
View and export historical messages |
Statistics |
View historical statistics |
Users |
Manage SwitchClient users and their access rights |
The workspace offers the following panes, which can be combined at will in the different views
Pane |
Canvas |
Displays and allows interaction with a flow design |
Dashboard |
Displays status information on problem jobs or processes, as reported by the Switch server |
Elements |
Lists the icons representing flow elements that can be dragged onto the canvas |
Files |
Serves to view and explore the contents of flow element backing folders (i.e. mostly jobs) Can also be used to view the contents of an arbitrary folder in the file system, but this is not a primary function |
Flows |
Lists all flows known to Switch at the present time |
Folders |
Serves to browse folders (not files) in the local file system and allows dragging backing folders to the canvas |
Messages |
Displays log messages produced by the Switch server during flow execution |
Messages 2, 3 |
Extra messages panes that may be configured with different settings for filtering or sorting messages |
Progress |
Displays progress information for tasks currently being executed by the Switch server |
Properties |
Displays the properties of the currently selected flow or flow element |
Statistics |
Displays statistics about job execution by the Switch server |
Statistics 2, 3 |
Extra statistics panes that may be configured to display a different set of statistics. |
Users |
Allows managing SwitchClient user names, passwords and access rights |
