This configurator drives Adobe Acrobat Distiller. It is a processor that converts a PostScript or EPS file into a PDF file. The resulting PDF file flows along the “data” output connections, Distiller’s log file flows along the “log” output connections.
The keywords for the Adobe Acrobat Distiller configurator are:
Detection mechanism |
Comments |
Automatic detection at startup |
Uses information registered with the operating system when the application is installed |
Searching from the elements pane |
Not provided |
Manually locating the executable |
This configurator supports any number of outgoing traffic-light connections.
Name |
PDF settings |
The Adobe PDF Settings used for creating PDF files (select from the Distiller library of PDF settings or browse for a file) |
