This configurator drives Adobe Acrobat Professional. It is a processor that offers a number of predefined PDF processing capabilities including merge pages, split pages, basic printing, and conversions to other file formats. In addition it supports executing a custom JavaScript in Acrobat, which allows automating most of the application's functionality from within Switch.
The keywords for the Adobe Acrobat Professional configurator are:
Users need to remember to enable JavaScript in the Acrobat Preferences, eg. in Acrobat 9, open the Acrobat preferences, select the section JavaScript, enable the checkboxes "Enable Acrobat JavaScript" and "Enable menu items JavaScript execution privileges".
Detection mechanism |
Comments |
Automatic detection at startup |
Uses information registered with the operating system when the application is installed |
Searching from the elements pane |
Not provided |
Manually locating the executable |
This configurator allows only a single outgoing connection.
Name |
Open |
The method used to open the incoming file; i.e. one of the following options:
Command |
The command to be performed; i.e. one of the following options:
Save as |
The method or format to save the file; i.e. one of the following options:
When the “Merge” open method is selected, the Acrobat configurator expects job folders coming in; individual files are moved to the Problem jobs folder. Each job folder must contain one or more PDF files to be merged into a single document. Files other than PDF are ignored.
The merge order is determined as follows:
If all filenames contain at least two numbers in the format as specified in the job assembler for assembling file sequences, the files will be merged in the order of the lowest number.
Otherwise, if all filenames contain at least one number, the files will be merged in the order of this number.
Otherwise, the files are merged in alphabetical order of filename.
When the “Split” save method is selected, the Acrobat configurator creates PDF files by splitting the incoming document into sections of one or more pages. The files are named by adding a prefix and/or suffix to the incoming file’s name (the suffix is added before the filename extension).
In the filename prefix and suffix specifications described below, the following character sequences (regardless of case) are replaced by the appropriate number for the file as follows:
Start: the one-based index of the first page contained in this file.
End: the one-based index of the last page contained in this file.
Total: the total number of pages in the original file.
The configurator shows the following extra properties for configuring the page splitting behavior:
Pages per file |
The number of pages in each output file (the default is one page per output file) |
Filename prefix |
The string pattern to be inserted before the filename (the default is the empty string) |
Filename suffix |
The string pattern to be inserted after the filename (the default is "_start-end_total") |
Make Job Folder |
If set to yes, all of the output files are stored inside a job folder (even if there is only one output file) and this job folder is injected into the outgoing connection as a single entity If set to no, each file is injected into the outgoing connections as a separate job. |
For example, with 2 pages per output file and with the default settings for prefix and suffix, a PDF file named "Brochure.pdf" containing 4 pages will result in 2 files with the following names:
Brochure_1-2_4.pdf
Brochure_3-4_4.pdf
When the "save as" property is set to a single-page file format (EPS, JPEG, JPEG2000, TIFF, PNG), Adobe Acrobat generates a distinct output file for each page in the PDF file. In this case, an additional property appears as described in the following table.
Make job folder |
If set to yes, all of the output files are stored inside a job folder (even if there is only one output file) and this job folder is injected into the outgoing connection as a single entity If set to no, each file is injected into the outgoing connections as a separate job In both cases, the filenames are under control of Adobe Acrobat |
The above assumes that Adobe Acrobat has been setup to save all pages. For example, Acrobat has a preference that defines which pages should be generated when saving as EPS. By default this is set to a single page; to generate an output file for each page in the PDF file, this should be set to "All". This preference resides at: Acrobat Preferences > Convert From PDF > Encapsulated PostScript -> Edit Settings > General > Page Range.
