Adobe Illustrator
This configurator drives Adobe Illustrator. It is a processor that allows various file format conversions. In addition it supports executing a custom JavaScript in Illustrator, which allows automating most of the application's functionality from within Switch.
Keywords
The keywords for the Adobe Illustrator configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed
Searching from the elements pane
Not provided
Manually locating the executable
Connections
This configurator allows only a single outgoing connection.
Properties
Property
Name
Open
The method used to open the incoming file; i.e. one of the following options:
  • Automatic: opens the incoming file in Illustrator without further instructions
  • Use script: executes a user-provided Javascript to open the incoming file in a customized manner; see JavaScript for applications for more information
Command
The command to be performed; i.e. one of the following options:
  • None: does nothing (other than what's specified for opening and saving the file)
  • Use script: executes a user-provided Javascript on the file for customized processing; see JavaScript for applications for more information
Save as
The method or format to save the file; i.e. one of the following options:
  • File format (various formats supported by Illustrator): saves the file in the selected file format; for some formats the configurator shows extra properties to set format-specific save options corresponding to those options available in the application; for other save options, Illustrator uses the option values that were set during the most recent interactive use
  • Use script: executes a user-provided Javascript to save the file in a customized manner; see JavaScript for applications for more information
