Adobe Photoshop
This configurator drives Adobe Photoshop. It is a processor that allows executing any Photoshop action in combination with conversions to other file formats if so desired. In addition it supports executing a custom JavaScript in Photoshop, which allows automating most of the application's functionality from within Switch.
Keywords
The keywords for the Adobe Photoshop configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed
Searching from the elements pane
Not provided
Manually locating the executable
Connections
This configurator allows only a single outgoing connection.
Properties
Property
Name
Open
The method used to open the incoming file; i.e. one of the following options:
  • Automatic: opens the incoming file in Photoshop, supporting a wide range of image formats in addition to PostScript and PDF;
    • Pixel images are opened with the resolution and color space as stored in the file.
    • Images previously saved from Photoshop as EPS or PDF are opened using the resolution and color space as stored in the file as Photoshop tags.
    • Other PostScript,EPS and PDF files are rasterized using the properties shown when the automatic option is selected: the resolution (in pixels per inch), the color space (Gray, RGB, CMYK or LAB) and Anti-aliasing (on or off).
  • Use script: executes a user-provided Javascript to open the incoming file in a customized manner; see JavaScript for applications for more information
Command
The command to be performed; i.e. one of the following options:
  • None: does nothing (other than what's specified for opening and saving the file)
  • Photoshop action: executes any Photoshop action on the file; the configurator shows an extra property to select a Photoshop action from those currently available in Photoshop
  • Use script: executes a user-provided Javascript on the file for customized processing; see JavaScript for applications for more information
Save as
The method or format to save the file; i.e. one of the following options:
  • File format (various formats supported by Photoshop): saves the file in the selected file format; for some formats the configurator shows extra properties to set format-specific save options corresponding to those options available in the application; for other save options, Photoshop uses the option values that were set during the most recent interactive use.
    When saving as PDF, EPS, JPEG or TIFF, you have the option to include the ICC profile in the file.
  • Saved by action: indicates that the Photoshop action specified for the command stage saves the file (see option "Photoshop action" for the "Command" property described above); this allows using Photoshop formats and format-specific save options that are not available directly from the configurator as described in the previous bullet item; the problem is however that the Photoshop action must provide the absolute path to the correct folder (i.e. the output folder of the configurator)
  • Use script: executes a user-provided Javascript to save the file in a customized manner; see JavaScript for applications for more information
