Altsoft Xml2PDF
This configurator drives Altsoft Xml2PDF Server. It is a processor that converts XML documents into formatted page-oriented output intended for human consumption.
Input formats include XSL-FO (or XML+XSLT), SVG, XHTML and Word (WordML 2003, DocX, Word 2007 Xml). Output formats include PDF, XPS, PS, and TIFF.
The formatted output file moves along the outgoing data connections, a log file with feedback on the conversion process moves along the outgoing log connections. If the formatting was successful, both files move along the success connections, otherwise they move along the error connections.
Keywords
The keywords for the Altsoft Xml2PDF configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed
Searching from the elements pane
Searches the system program files folder for the application
Manually locating the executable
Select the "Xml2PDF Commander" executable
Connections
This configurator supports any number of outgoing traffic-light connections.
Properties
Property
Name
Output format
The format of the resulting output file; choices are: PDF, PostScript, XPS, TIFF
Conformance
Conformance to various ISO standards (PDF output only)
Choices are: None, PDF/X-1a:2003, PDF/X-3:2003, PDF/A-1a, PDF/A-1b
Output condition
Output color condition (PDF output only)
In case of "PDF/X-1a:2003" conformance this should be either "custom" or one of the CMYK-based standard conditions
Choices are: custom, Ifra News print 22%, Ifra News print 28%, ISO Coated, ISO News print 26%, ISO News print 30%, ISO Uncoated, ISO Uncoated Yellowish, ISO Web Coated, Japan Color 2001 Coated, Japan Color 2001 Uncoated, Japan Color 2002 Newspaper, Japan Web Coated (Ad), U.S. Web Coated (SWOP), sRGB IEC61966-2.1, bg-sRGB IEC61966-2.1, sYCC IEC61966-2.1, ROMM-RGB, eciRGB, Adobe RGB (1998)
Color profile
Color profile for the output (PDF output only)
Required if output condition is set to "custom"; optional otherwise
The profile's color space must match the color model of the PDF output condition
Report type
The type of the report generated during formatting; choices are: None, Text, XML
Configuration file
Path to an Xml2PDF configuration file with additional settings; if no configuration file is specified, the default settings are used
A configuration file can be created and edited with the free desktop application “Altsoft Xml2PDF Workstation 2007” available at the Altsoft download center
XSLT transform
Path to a file containing an XSLT transform (style sheet) that should be applied to the incoming XML file before formatting (optional)
Background
Path to the document to be used as background
Background usage policy
Indicates how background is applied for multi-page output:
  • First page - use first page of the background document as background for all pages of the output document
  • All pages - use subsequent pages of the background document for the corresponding pages of the formatted document
Protected
Specifies whether the resulting PDF document should be password protected (supported only for PDF output format)
User password
The password required to open the protected document, or empty if there is no open password
Owner password
The password required to unlock the document protection
Allow modification
Specifies whether the protected document can be modified
Allow extraction
Specifies whether text and images can be extracted from the protected document
Allow printing
Specifies whether printing the protected document is allowed
Allow high-quality printing
Specifies whether high quality printing (150 dpi and higher) of the protected document is allowed
