This configurator drives Apago PDF Enhancer, Server or Advanced Server edition. It is a processor that modifies a PDF file in a specified way. The resulting PDF file flows along the “data” output connections, the log file flows along the “log” output connections.
The keywords for the Apago PDF Enhancer configurator are:
Detection mechanism |
Comments |
Automatic detection at startup |
Uses information registered with the operating system when the application is installed |
Searching from the elements pane |
Not provided |
Manually locating the executable |
Select the executable for the command-line version of the application |
This configurator supports any number of outgoing traffic-light connections.
Name |
PDF Enhancer target |
The Apago PDF Enhancer target that specifies how to modify the file (browse for a target file saved from PDF Enhancer) |
