Archive hierarchy
Archive hierarchy is a consumer that creates a nested hierarchy with one or more levels of subfolders. It is used to archive jobs into a structured hierarchy at the end of a flow. The resulting jobs are to be consumed (and removed) by an external process. The backing folder (on disk) for an archive hierarchy should typically be user-managed.
It is not allowed for an external process or a user to place files into an archive hierarchy.
An archive hierarchy uses the hierarchy location path stored in a job’s internal job ticket to determine where the job should be stored, up to the nesting level specified for the archive hierarchy. Any superfluous segments in a location path are ignored. Subfolders are created automatically.
See Using hierarchy info for more details.
Keywords
The keywords for the Archive hierarchy element are:
Connections
Archive hierarchy does not allow outgoing connections
Properties
Property
Name
Path
The path of the archive hierarchy's backing folder on disk, or "auto-managed"
Subfolder levels
The number of nested subfolder levels in the archived structure; see also the description on subfolders earlier.
Strip unique name
If set to yes, the unique name prefix added to the filename by Switch is removed before placing the job in the archive hierarchy; the default is to strip the prefixes from jobs deposited in an archive hierarchy - leaving the prefixes in place avoids overwriting a previously deposited job with the same name
Duplicates
Determines what happens when "Strip unique name" is set to yes and a job arrives with the same name and location as a job already residing in the hierarchy:
  • Overwrite: replace the existing job with the new one – this is the default behavior
  • Keep unique name: preserve the new job’s unique name prefix, leaving the existing job untouched (without unique name prefix)
  • Add version number: add an incrementing version number at the end of the filename body for the new job (“2”, “3”, … “9”, “10”, “11”), leaving the existing job untouched
  • Fail: move the new job to the problem jobs folder, leaving the existing job untouched
