callas pdfAutoOptimizer
This configurator drives callas pdfAutoOptimizer, a plug-in for Adobe Acrobat Professional 8.1.
It is a processor that optimizes a PDF file according to specifications, including transparency flattening.
Keywords
The keywords for the callas pdfAutoOptimizer configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
For Adobe Acrobat: uses information registered with the operating system when the application is installed
For the pdfAutoOptimizer plug-in: checks whether the plug-in is present in the Acrobat plug-ins folder
Searching from the elements pane
Not provided
Manually locating the executable
Not provided
Connections
This configurator allows only a single outgoing connection.
Properties
Property
Name
Optimizer setting
The name of the PDF optimizer setting to be used, selected from the list published by pdfAutoOptimizer
These settings are configured using the standard Acrobat PDF Optimizer user interface
Color space
The color space used during transparency flattening, specified in one of the followingways:
  • Drop-down list: DeviceGray, DeviceCMYK, DeviceRGB
  • Select from library: a list of names published by pdfAutoOptimizer
  • Choose file: any ICC color profile (CMYK, RGB or Gray)
  • Script expression and text with variables: evaluate to either a value known in the drop-down list or library, or an absolute file path to an ICC profile
  • The empty string: means “don’t set color space”’
