This configurator drives callas pdfCorrect, CLI edition. It is a processor that corrects a PDF file according to specifications. The resulting PDF file flows along the “data” output connections, the log file flows along the “log” output connections.
The keywords for the callas pdfCorrect configurator are:
Detection mechanism |
Comments |
Automatic detection at startup |
Uses information registered with the operating system when the application is installed (Windows) or checks the default install location (Mac) |
Searching from the elements pane |
In addition to the above, searches the system program files/applications folder for the application |
Manually locating the executable |
Select the executable for the command-line version of the application |
This configurator supports any number of outgoing traffic-light connections.
Name |
Source settings |
The callas configuration file that specifies the source color settings (browse for a configuration file shipped with pdfColorConvert CLI or saved from a plug-in version of pdfColorConvert) |
Correction profile |
The callas correction profile that specifies how to modify the file (browse for a correction profile shipped with pdfCorrect CLI or saved from a plug-in version of pdfCorrect) |
