callas pdfInspektor
This configurator drives callas pdfInspektor3 and pdfInspektor4, CLI editions. It is a processor that preflights a PDF file according to specifications. The PDF file itself flows along the “data” output connections, the preflight report flows along the “log” output connections.
Keywords
The keywords for the callas pdfInspektor configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed (Windows) or checks the default install location (Mac)
The configurator first looks for pdfInspektor4, then for pdfInspektor3
Searching from the elements pane
In addition to the above, searches the system program files/applications folder for the application
Manually locating the executable
Select the executable for the command-line version of the application
Connections
This configurator supports any number of outgoing traffic-light connections.
Properties
Property
Name
Preflight profile
The callas preflight profile to be used to preflight the file; browse for a profile package (*.kfp) shipped with pdfInspektor or saved from Adobe Acrobat, which uses the callas preflight technology (Acrobat 7 corresponds to pdfInspektor3; Acrobat 8 corresponds to pdfInspektor4)
Report type
The format of the preflight report; choices include:
  • Text: plain text file (UTF-8 encoding) intended to be processed by software
  • Compact: plain text file (UTF-8 encoding) intended for human readers
  • XML: XML file with informal schema
  • XMLV2: XML file that formally conforms to the XML schema installed with pdfInspektor4 (available only for pdfInspektor4; for pdfInspektor3 this choice automatically reverts to XML)
  • PDF mask: original PDF file with semi-transparent masks inserted on new layers to visually indicate preflight problems
  • PDF comments: original PDF file with comments inserted to indicate preflight problems.
  • PDF layer: original PDF file with certain text, graphics and image objects separated on different layers; this is more than strictly a report format (see PDF layer report type below)
  • Inventory: PDF document that provides statistics; intended for human readers (see Inventory report type below)
Report language
The human language for the preflight report; choices include: Danish, German, English, Spanish, Finnish, French, Italian, Japanese, Korean, Dutch, Norwegian, Portuguese, Swedish
Max errors per document
The maximum number of errors reported for a document
Max errors per page
The maximum number of errors reported for a page
Allow PDF/X or PDF/A conversion
If set to yes, and the selected preflight profile specifies PDF/X or PDF/A conversion, and the original PDF file can be converted, the configurator moves the converted PDF/X or PDF/A file along the outgoing data connections; otherwise it moves the original PDF file along the outgoing data connections (see PDF/X or PDF/A conversion below)
Text and XML report types
The following extra properties are shown for Text and XML report types; the first property in the table is also shown for the XMLV2 report type.
Property
Include problem details
If set to yes, the report includes all details for objects causing a preflight problem (this corresponds to the “text-long” report format offered in the Switch 06 configurator)
Include page resources
If set to yes, resources such as color spaces and fonts are listed for each page
Include page information
If set to yes, information such as page size is listed for each page
Include document resources
If set to yes, resources such as color spaces and fonts are listed for the document as a whole
The following extra properties are shown for the PDF layer report type. They allow specifying which objects should be extracted to separate layers. For example, when the “Separate spot colors” property is set to yes, all objects painted with a spot color are placed on a new layer named for the spot color.
Property
Separate fonts
If set to yes, the report has a separate layer for each font used in the original PDF
Separate ICC profiles
If set to yes, the report has a separate layer for each ICC profile used in the original PDF
If set to yes, the report has a separate layer for each spot color used in the originalPDF
The following extra properties are shown for the Inventory report type.
Property
Include fonts
If set to yes, information on fonts is included
Include colors
If set to yes, information on colors is included
Include shades
If set to yes, information on shades is included
Include patterns
If set to yes, information on patterns is included
Include images
If set to yes, information on images is included
Minimum image size (pixels)
Only information for images larger than this threshold is included
(this property value is used only if “include images” is set to yes)
Include form xobjects
If set to yes, information on form XObjects is included
Include XMP
If set to yes, information on XMP metadata is included
Include XMP advanced
If set to yes, advanced information on XMP metadata is included
The Inventory report type does not require a preflight profile. In fact it is invalid to provide a preflight profile when this report type is selected.
For PDF/X or PDF/A conversion to take place, the following three conditions must be simultaneously satisfied:
The “Allow PDF/X or PDF/A conversion” property is set to yes.
The profile selected in the “Preflight profile” property specifies PDF/X or PDF/A conversion.
The incoming PDF file can be successfully converted to the specified flavor of PDF/X or PDF/A.
The configurator’s behavior in various situations is summarized in the following table.
Profile specifies conversion
Incoming file can be converted
Result placed on data connections
Level of success on connections
No
don’t care
don’t care
Original file
Depending on preflight result
Yes
No
don’t care
Original file
Yes
Yes
No
Original file
Error
Yes
Yes
Yes
Converted file
Success or warning
