The following table describes the columns in the messages pane. You can resize and reorder the columns by dragging the column headers.
Column |
Time stamp |
The moment in time when this message was issued |
Type |
The message type, such as Info or Error (see below) |
Module |
The Switch module (such as Control) or type of flow element that issued this message |
Flow |
The name of the flow issuing this message |
Flow element |
The name of the flow element issuing this message |
Job |
The name of the job for which this message was issued |
Job Prefix |
The unique name prefix of the job referred in the message, or blank if there is no unique name prefix |
Message |
The message itself |
Type |
Info |
An informational message that has no other purpose than to inform the user of a certain occurrence |
Warning |
A warning message that informs the user of a recoverable problem or non-fatal error |
Error |
An error message that informs the user of a fatal error |
Debug (*) |
An informational message solely intended for debugging purposes |
Assert (*) |
A message solely intended for debugging purposes that is issued only when a coding error is discovered |
(*) Messages of these types are stored in the log database only when the "Log debug messages" user preference is turned on (see logging preferences).
