Adstream PrintSure
This configurator drives Adstream PrintSure, CLI edition. It is a processor that preflights and/or corrects a PDF file according to specifications. The resulting possibly corrected PDF file flows along the “data” output connections, the preflight report or reports flow along the “log” output connections.
Keywords
The keywords for the Adstream PrintSure configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Not provided
Searching from the elements pane
Searches the system program files/applications folder for the application
Manually locating the executable
Select the executable Java archive for the command line version of PrintSure ("printsure-sdk.jar")
Connections
This configurator supports any number of outgoing traffic-light connections.
Notes
Properties
Property
Name
PrintSure profile
A path to an XML file (with the “.xml” filename extension) that defines a PrintSure profile with preflight and correction settings
PrintSure profiles can be created and edited using the public profile editor web interface offered by DevZeroG (refer to the PrintSure CLI documentation)
Produce PDF report
If set to yes, the configurator outputs a regular preflight report for human consumption in PDF format
The report file has the same name as the incoming file with the suffix “-Report” and the extension “pdf”
Produce commented PDF
If set to yes, the configurator outputs a copy of the incoming file with added PDF comments indicating any preflight issues
The report file has the same name as the incoming file with the suffix “-Commented” and the extension “pdf”
Produce XML report
If set to yes, the configurator outputs a preflight report for automated consumption in XML format
The report file has the same name as the incoming file with the suffix “-Report” and the extension “xml”
Produce plain text report
If set to yes, the configurator outputs a plain text report in UTF-8 encoding
The report file has the same name as the incoming file with the suffix “-Report” and the extension “txt”
