Elpical Claro
This configurator drives Elpical Claro, CLI edition. It is a processor that enhances an image file or the images in a PDF file according to the settings specified in the configurator properties. The resulting enhanced image file or PDF file flows along the single outgoing connection.
Keywords
The keywords for the Elpical Claro configurator are:
File formats
Besides processing PDF documents, Claro can process single image files.
For input, Claro supports a wide range of image file formats through the Java ImageIO library. The following file formats have been tested by Elpical: JPEG, TIFF, EPS, GIF, PNG, BMP, PSD.
For output, Claro supports only the following file formats: JPEG, TIFF, EPS.
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed (Windows) or checks the default install location (Mac)
Searching from the elements pane
In addition to the above, searches the system program files/applications folder for the application
Manually locating the executable
Select the executable for the command-line version of the application
Connections
This configurator allows only a single outgoing connection.
Properties
Property
Name
Channel ID
A unique number for each concurrent flow element
Max memory (MB)
The maximum memory this process will claim
Use minimum image size in PDF
This limits the number of images to be processed
…Minimum size (pixels)
The minimum size in pixels for an in image to be processed
Apply resampling
Images are resampled
…Resolution (dots per inch)
Images are resampled with this value (dots per inch)
Max image size input
Larger images will be rejected for processing
...Value (megapixels)
The maximum input size in megapixels (for example 25 means 25.000.000 pixels)
Apply sharpness
Images are sharpened with halo reduction
…Value [-5.0, 5.0]
A value must be entered between -5.0 and +5.0
Apply brightness
Images are enhanced according to a gamma adjustment
… Value [-5.0, 5.0]
Apply contrast
Images are enhanced in highlights and shadows
… Value [-5.0, 5.0]
Apply saturation
Images are enhanced in color saturation
… Value [-5.0, 5.0]
Set black and white point
The luminance level is stretched in images
Apply noise filter
A noise filter is applied to noisy images
Apply local contrast
Parts of the image are improved in contrast when applicable
Adjust color balance
A bad color shift is adjusted
Use embedded profile
When there is a color profile embedded in the image, it will be used as source profile
Use original RGB
Use original RGB as working profile (this will overrule the configured working profile)
Don't process CMYK images in PDF
If the PDF contains CMYK images, they will not be processed
Assumed profile RGB
When there is no color profile embedded in an RGB image, the specified profile is assumed as source profile
Assumed profile CMYK
When there is no color profile embedded in a CMYK image, the specified profile is assumed as source profile
Working profile RGB
The specified color profile is used as working space for processing images
Output profile for color
If a color profile is specified, a color image is converted to this profile
Output profile for B&W
If a color profile is specified, a B&W image is converted to this profile
Embed profile in image
The output color profile is embedded in the image
Output file format
The output format for images (PDF always remains PDF); choose one of the following:
  • Original: incoming JPEG, TIFF or EPS files are output in the same format; any other images are output as TIFF.
  • JPEG, TIFF, or EPS (with various options): all images are output in the specifiedformat.
JPEG compression
The compression quality for JPEG output format
Generate extra log messages
Extra information about the process is logged
