Enfocus PitStop Server
This configurator drives Enfocus PitStop Server. It is a processor that preflights and/or corrects a PDF file according to specifications. The resulting PDF file flows along the “data” output connections, the preflight report flows along the “log” output connections.
Keywords
The keywords for the Enfocus PitStop Server configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed.
Searching from the elements pane
In addition to the above, searches the system program files/applications folder for the application
Manually locating the executable
Not provided
Connections
This configurator supports any number of outgoing traffic-light connections.
Properties
Property
Name
PDF profile
The Enfocus Preflight Profile to be used to preflight and possibly correct the file (select an item from the library stored inside PitStop Server, or browse for a Preflight Profile saved from PitStop Server or PitStop Pro)
The Preflight Profile can be omitted in case one or more Action Lists are specified (in the next property)
Action list(s)
A sequence of Action Lists to be executed on the file (select one ore more items from the library stored inside PitStop Server, or browse for an Action List saved from PitStop Server or PitStop Pro)
The sequence of Action Lists can be empty in case a Preflight Profile is specified (in the previous property)
Certified PDF
Determines Certified PDF-related behavior while processing the file as one of these choices:
  • Unchanged
  • Save as uncertified
  • Start certified
Allow rollback
If set to yes, the output file preserves the Certified PDF history information allowing rollback to previous Certified PDF sessions
Set personal info
If set to yes, three extra properties appear for defining the personal information listed on the preflight report and used for the Certified PDF session created by processing the file
User name
The user name in the personal info
Company name
The company name in the personal info
Email address
The email address in the personal info
Color management for images
Determines whether PitStop Server uses color management to process the file
If set to yes, the configurator shows a series of extra properties to specify color profiles and rendering intent
Gray source Gray target RGB source RGB target CMYK source CMYK target LAB source LAB target
These properties specify source and target color profiles for various color spaces
Select a color profile from the library stored inside PitStop Server or browse to a standard ICC profile file
Output intent overrides selected source ICC profile
Specifies whether the ICC profile of the output intent in the PDF should be used instead of the selected source ICC profile
Output intent overrides selected target ICC profile
Specifies whether the ICC profile of the output intent in the PDF should be used instead of the selected target ICC
CMM Engine
The color management engine used for color conversions. Choices are System CMM, Little CMM and Adobe CMM
Rendering intent
Specifies the rendering intent for color management; choices are:
  • Object defined
  • Relative colorimetric
  • Absolute colorimetric
  • Saturation
  • Perceptual
Color management for other objects
Specifies the color management mode for objects other than images; choices are:
  • Same as images: color management for all objects is specified by “Use color management”property and its subordinates
  • Different: color management for other objects is turned on and defined by the subordinate properties following below; color management for images is defined by the “Use color management” property and its subordinate properties
  • Off: color management for other objects is turned off; color management for imagesis defined by the “Use color management” property and its subordinate properties
If this property is set to "Different", the configurator shows a series of extra properties to specify color profiles and rendering intent (similar to the extra properties shown for "use color management")
Extra font folder
Path to a folder that contains extra fonts for use while processing files (in addition to the system fonts)
Optimization
The optimization performed: optimized for web download; optimized for file size only; not optimized
Report type
The format of the preflight report; choices are: PDF, PDF minimum, PDF continuous, XML, Text summary, XML summary (see section on report types below)
Hyperlinks include unique name prefix
A PDF report contains hyperlinks to the file being processed; this property determines whether the filename in those hyperlinks includes the Switch unique name prefix or not
In both cases the hyperlinks are relative to the file's position, so the preflight report and the file being processed must remain in the same folder for the hyperlinks to work
Additional XML Report dataset
The name of an additional dataset where an XML report will be stored
Report language
The human language for the preflight report; choices include: English, German, French, Italian
Measurement units
The measurement units used in the report; choices are: Points, Picas, Inches, Centimeters, Millimeters
Report types
The following table lists the report types offered by the PitStop Server configurator.
Report type
Generated by
PDF
Regular PDF preflight report format
PitStop Server
PDF minimum
Minimum PDF preflight report format
PitStop Server
PDF continuous
Continuous PDF preflight report format
PitStop Server
XML
XML preflight report format
PitStop Server
Text summary
Plain text summary of the preflight report in UTF-8 encoding
Switch configurator
XML summary
XML summary of the preflight report
Switch configurator
Customized PDF reports
PitStop Server can generate customized PDF reports using a template provided by the user. When driving PitStop Server via Switch, you must replace the report templates provided by Switch in the following location:
The names of the report templates correspond to the report types as follows:
Report type
Report template filename
PDF
ServerReportDefault
PDF minimum
ServerReportMinimal
PDF continuous
ServerReportGrayscale
Annotated
ServerReportAnnotated
Annotated low res
ServerReportAnnotatedLowRes
