Error handling
These preferences configure error handling and retry behavior for problem processes.
Property
Abort file transfers after (minutes)
If an FTP or email file transfer takes longer than this time, it is considered crashed or locked-up and it is aborted (0 means never abort)
Abort processes after (minutes)
If a process other than a file transfer takes longer than this time, it is considered crashed or locked-up and it is aborted (0 means never abort)
Retry mail transfers after (minutes)
Time interval in minutes between retrying a failed email transfer (0 means “don’t retry” which is not recommended)
Retry FTP transfers after (minutes)
Time interval in minutes between retrying a failed FTP transfer (0 means “don’t retry” which is not recommended)
Retry unreachable folder after (minutes)
Time interval in minutes between retrying an unreachable folder (0 means “don’t retry” which is not recommended)
Retry failed external processes after (minutes)
Time interval in minutes between retrying a failed external process (0 means “don’t retry” which in this case is the recommended value)
