Evaluating XPath expressions
The functions presented here evaluate an XPath 1.0 expression in the context of the node being queried.
Namespaces
Result data types
The value of an XPath 1.0 expression can have several data types (a node set with several elements, the text value of an attribute, a number returned by the count() function, the Boolean result of a comparison). The value is converted to the function's result data type using XPath 1.0 semantics – which may very well differ from the conversion semantics in the scripting language. For example the XPath 1.0 conversion from string to Boolean returns true for all non-empty strings (including the string “false”).
Functions
evalToNodes( xpath : String, prefix-map : Map ) : NodeList
Evaluates an XPath 1.0 expression in the node’s context. If the result is a non-empty node-set, returns a list of the nodes in the set. Otherwise returns an empty list.
evalToNode( xpath : String, prefix-map : Map ) : Node
Evaluates an XPath 1.0 expression in the node’s context. If the result is a non-empty node-set, returns the first node in the set. Otherwise returns null.
evalToString( xpath : String, prefix-map : Map ) : String
Evaluates an XPath 1.0 expression in the node’s context and converts the result to a string value with the XPath 1.0 string() function.
evalToNumber( xpath : String, prefix-map : Map ) : Number
Evaluates an XPath 1.0 expression in the node’s context and converts the result to a numeric value with the XPath 1.0 number() function.
evalToBoolean( xpath : String, prefix-map : Map ) : Boolean
Evaluates an XPath 1.0 expression in the node’s context and converts the result to a Boolean value with the XPath 1.0 boolean() function.
