FileStatistics class
The FileStatistics class allows retrieving certain statistics about file contents for a number of supported file formats. The class does not allow modifying file contents.
Each FileStatistics instance references a particular file, which may be any file on the local file system (whether it is a job or not). The FileStatistics class does not support folders.
Constructing
FileStatistics( file-path : String ) : FileStatistics
Constructs a FileStatistics instance associated with a file specified through its absolute file path. If the specified path references a folder rather than file, the constructed instance behaves as if the referenced file doesn’t exist.
Getting file system attributes
The functions in this section work independently of the file’s file format.
getPath( ) : String
Returns the absolute file path.
getName( ) : String
Returns the filename including filename extension if present.
getNameProper( ) : String
Returns the filename excluding filename extension.
getExtension( ) : String
Returns the filename extension, or the empty string if there is none.
getMacType( ) : String
Returns the Mac file type code as a 4-character string if available, otherwise the empty string.
getMacCreator( ) : String
Returns the Mac creator code as a 4-character string if available, otherwise the empty string.
isType( ext : String ) : Boolean
Returns true if the file matches the specified file type, specified as a filename extension, and false otherwise. A file matches if its filename extension and/or its Mac file type (after conversion) match the specified filename extension.
This function does not examine the file contents.
isFile( ) : Boolean
Returns true if the file exists, false otherwise.
getByteCount( ) : Number
Returns the size in bytes of the file, or zero if the file doesn’t exist.
getCreated( ) : Date
Returns the creation time of the file, or null if the file doesn’t exist.
getModified( ) : Date
Returns the last modification time of the file, or null if the file doesn’t exist.
Accessing embedded metadata
getEmbeddedDataset( ) : Dataset
Returns a read-only embedded metadata dataset object with the XMP data model for the metadata embedded in the file, or null if the file doesn’t exist. If the file exists but it has no supported embedded metadata, the function returns a valid but empty dataset.
The backing file path for the dataset points to the file. Metadata may be embedded in the file as an XMP packet and/or as binary EXIF or IPTC tags. Metadata fields from multiple sources are synchronized into a unified XMP data model. See supported file formats for more information.
This function behaves similarly to the Job.getEmbeddedDataset() function; it supports the same file and metadata formats and performs the same synchronizations. The advantage is that it can be used with any file (for example, to iterate over all files inside a job folder). It does not however allow metadata updates (it always returns a read-only dataset) and it does not support folders (i.e. it doesn’t look for an appropriate backing file inside a folder).
Recognizing file format
The functions in this section recognize file format by looking at the file contents. The current implementation supports the following formats:
Filename extension
AI
Adobe Illustrator (internal format is PDF)
AVI
Video clip
EPS
Encapsulated PostScript
INDD
Adobe InDesign
JPEG
JPEG image
MOV
QuickTime movie
MP3
MP3 sound
PDF
Adobe PDF (Portable Document Format)
PNG
PNG image
PS
Adobe PostScript
PSD
Adobe Photoshop
TIFF
TIFF image
WAV
Wave sound
getFileFormat( ) : String
Returns the format of the file contents (as one of the strings in the first column of the table above), or the empty string if the format is not recognized or if the file doesn’t exist. This function checks for all supported file formats, so it may be a bit slow.
isFileFormat( format : String ) : Boolean
Returns true if the file exists and its contents has the specified format (as one of the strings in the first column of the table above); otherwise it returns false. This function is faster than getFileFormat() since it has to check for only a single file format.
Getting contents statistics
The functions in this section interpret the file contents to obtain certain file-format-specific statistics. The requested statistic is specified through its name (as defined for each format in subsequent sections). Each statistic has a well-defined data type (listed with its description). It is recommended to use the “get” function with the appropriate data type, but reasonable conversions between data types are supported.
The functions return the null object (as opposed to an empty string or a zero number) if:
getString( query : String ) : String
Returns the requested statistic as a string.
getStringList( query : String ) : String[ ]
Returns the requested statistic as a list of strings.
getNumber( query : String ) : Number
Returns the requested statistic as a number.
getBoolean( query : String ) : Boolean
Returns the requested statistic as a Boolean.
getDate( query : String ) : Date
Returns the requested statistic as a date-time.
Data type conversions
Statistic data type
String
Number
Boolean
Date
String
Straightforward
Decimal number representation
Interpret as in the XMP data model
Interpret ISO 8601 date-time representation
Integer
Decimal representation of the number
Straightforward
False if zero; true if nonzero
Not supported
Rational
Decimal floating point representation of the number
Straightforward
Not supported
Boolean
“true” or “false”
1 or 0
Straightforward
Not supported
Date
ISO 8601 representation of the date-time
Not supported
Not supported
Straightforward
A string list is converted to another data type by converting the first string in the list (if the list is empty, the conversion is not supported). Any other data type is converted to a string list by converting it to a string and forming a list of one item.
Supported statistics
Statistic name
Data type
Supported for
NumberOfPages
Integer
All formats
The number of pages in the document (or a value of one if the format doesn’t support multiple pages)
SamplesPerPixel
Integer
JPEG, TIFF, PNG
Number of components per pixel
PixelXDimension
Integer
JPEG, TIFF, PNG
Valid image width, in pixels
PixelYDimension
Integer
JPEG, TIFF, PNG
Valid image height, in pixels
ColorMode
Integer
JPEG, TIFF, PNG
The color mode used: 0 = Bitmap; 1 = Gray; 2 = Indexed color; 3 = RGB; 4 = CMYK; 7 = Multichannel; 8 = Duotone; 9 = Lab color
ColorSpace
Integer
JPEG, TIFF, PNG
Color space information: 1 = sRGB; 65535 = uncalibrated
ICCProfile
String
JPEG, TIFF, PNG
The name of ICC color profile used, if any
Colorants
String list
TIFF
A list of the names of all colorants for Duotone or Multichannel images; the list is empty for all other color models
CellWidth
Integer
TIFF
The width of the dithering or halftoning matrix used to create a dithered or halftoned bilevel file
CellLength
Integer
TIFF
The length of the dithering or halftoning matrix used to create a dithered or halftoned bilevel file
TileWidth
Integer
TIFF
The width (number of columns) of each tile
TileLength
Integer
TIFF
The length (number of rows) of each tile
ColorIntent
Integer
PNG
The sRGB rendering intent:
0 = Perceptual, 1 = RelativeColorimetric,
2 = Saturation, 3 = AbsoluteColorimetric
4 = invalid value
Version
String
PDF
The version of the file format (for example “1.6”)
PageWidth
Rational
PDF
The width of the first page in the document, in points (derived from the media box)
PageHeight
Rational
PDF
The height of the first page in the document, in points (derived from the media box)
PageLabels
String list
PDF
A list of the page labels for all pages in the document, or null if none of the pages has a page label
Colorants
String list
PDF
A list of the names of all colorants as they appear in Separation and DeviceN color spaces and in page separation info dictionaries in the document
Fonts
String list
PDF
A list of the names of all fonts (without subsetting prefix) as they appear in font dictionaries in the document
SecurityMethod
String
PDF
The method used to protect the document; possible values: "None", "Password", "Certificate", "LiveCycle"
PDF media boxes
The FileStatistics class offers the following additional statistics for the PDF file format:
Statistic name
Data type
PageBoxesEqual
Boolean
True if all pages have identical page boxes; false otherwise (verifies media, crop, bleed, trim and art box)
MediaBoxWidth
Rational
The width of the media box for the first page in the document, in points
This is a synonym for the ‘PageWidth’ statistic
MediaBoxHeight
Rational
The height of the media box for the first page in the document, in points
This is a synonym for the ‘Pageheight’ statistic
CropBoxWidth
Rational
The width of the crop box for the first page in the document, in points
CropBoxHeight
Rational
The height of the crop box for the first page in the document, in points
BleedBoxWidth
Rational
The width of the bleed box for the first page in the document, in points
BleedBoxHeight
Rational
The height of the bleed box for the first page in the document, in points
TrimBoxWidth
Rational
The width of the trim box for the first page in the document, in points
TrimBoxHeight
Rational
The height of the trim box for the first page in the document, in points
ArtBoxWidth
Rational
The width of the art box for the first page in the document, in points
ArtBoxHeight
Rational
The height of the art box for the first page in the document, in points
PDF/X version key
Statistic name
Data type
PDFXVersionKey
String
The contents of the PDF/X version key in the document, or the empty string if there is no such key; one of the following values may be returned:
  • PDF/X-1a:2001
  • PDF/X-3:2002
  • PDF/X-1a:2003
  • PDF/X-3:2003
  • PDF/X-4
  • PDF/X-4p
The PDF/X version key indicates a claim that the document conforms to the PDF/X specification, but it does not offer any guarantees
PDF page content
The FileStatistics class offers the following additional statistics for the PDF file format.
Obtainging the information for these statistics requires parsing the complete page contents, so it might be time consuming.
Statistic name
Data type
ColorSpaceFamilies
String list
A list of the names of all color space families actually used in the document’s page contents; the following names may be returned:
DeviceGray, DeviceRGB, DeviceCMYK, CalGray, CalRGB, Lab, ICCBasedGray, ICCBasedRGB, ICCBasedCMYK, Indexed, Pattern, Separation, DeviceN.
For Indexed or Pattern, the underlying color space families are also listed
TransparentColor
Boolean
True if the document’s page contents uses transparency for defining colors; false otherwise
FontTypes
String list
A list of the names of all font types actually used in the document’s page contents; the following names may be returned:
  • TrueType
  • Type1
  • Type3
  • MultipleMaster
  • Composite
