This configurator drives Jaws PDF Creator from Global Graphics. It is a processor that converts a PostScript or EPS file into a PDF file. The resulting PDF file flows along the “data” output connections, the log file flows along the “log” output connections.
The keywords for the Jaws PDF Creator configurator are:
Detection mechanism |
Comments |
Automatic detection at startup |
Uses information registered with the operating system when the application is installed |
Searching from the elements pane |
Not available |
Manually locating the executable |
Select the command line tool that is installed with the application |
This configurator supports any number of outgoing traffic-light connections.
Name |
Configuration |
The name of the Jaws PDF Creator configuration to use when converting PostScript to PDF (selected from the list of configurations stored in Jaws PDF Creator - and setup through its regular user interface) |
