Logging
Property
Saving log messages
Determines the mechanism for saving log messages into Switch's logging database:
  • Fast: uses delayed writing to increase speed but risks loosing messages in case of an operating system crash or power failure
  • Safe: writes each message to disk before proceeding; this guarantees that no messages are lost but it can be quite slow when Switch logs many messages per second (in practice the "fast" option is almost always preferred)
Export messages to XML
When set to “yes” the messages stored in the execution log are automatically exported to daily XML files, starting with the day on which the feature was turned on
The export happens 5 minutes after midnight; if days were skipped because Switch wasn’t active, the missing days are exported 5 minutes after the next startup
The name of the exported files include the Switch server name (see internal communication preferences) and the date in the format: “<server-name> logs YYYY-MM-DD.xml”
See Exporting log messages for information on the XML schema of the exported files
Destination folder
The folder where the exported XML files are placed
To process the exported XML files with Switch, set the destination folder to the input folder of an active flow
Log debug messages
When set to “yes” any debug messages are written to the regular log database (normally they are ignored)
Turn on this preference only when so requested by Enfocus Support, or when you are debugging a script that issues debug messages
Log to text file
When set to “yes” all execution log messages (including debug messages) are written to a comma-separated text file in addition to the regular log database
