Monitor confirmation
Monitor confirmation is a processor that monitors incoming receipt confirmations (generated by Unpack job) and matches them against a copy of the packed data (generated by Pack job) waiting in its input folder. When no confirmation is received after a certain amount of time, tool can be setup to retry the communication (i.e. send another copy of the packed data).
See Acknowledged job hand-off for an example of how to use this tool.
Keywords
The keywords for the Monitor confirmation element are:
Connections
Monitor confirmation supports outgoing traffic-light connections of the following types to support its various actions:
Action
Connection type
Comments
Confirm
Success data
When a matching confirmation is received, the packed data is removed from the input folder and sent along this connection
Success log
When a matching confirmation is received, it is sent along this connection
Retry
Warning data
For each retry attempt (as specified by the tool’s properties) a copy of the packed data is moved along this connection; the original packed data stays in the input folder
Reject
Error data
After all retries have timed-out, the packed data is removed from the input folder and sent along this connection
Error log
When a confirmation is received that doesn’t match any of the waiting packed data files, or that is corrupt, it is sent along this connection
Properties
Property
Name
Retry count
The number of retry attempts made when no confirmation is received
Retry delay (minutes)
The delay (in minutes) between each retry attempt and the timeout after the last one
