OASIS support
addOasisSecurity ( username : String, password : String, passwordtype : String ) : Boolean
This call modifies the SOAP header to include an OASIS security header. It adds a wsse:Security element with a wsse:UsernameToken of the specified password type. Any existing wsse:Security element is replaced by the new element.
The following table describes the parameters and return value.
Parameter
url
The URL for a SOAP HTTP endpoint, e.g. http://serverName:portNumber/URI
request object
An object that specifies the remote procedure name and parameters of the XML message to send; see separate section below
action
The SOAPAction, a URN written to an HTTP header used by firewalls and servers to filter SOAP requests; the SOAP service description will usually describe the SOAPAction header required, if any
The default is for the action to be an empty string
response object
An object that describes the return value received by the remote procedure call; see separate section below
username
The username used for authentication
password
The password used for authentication
passwordtype
One of “PasswordText” or “PasswordDigest”.
Qualified names
In the request object, a qualified name is specified as a string in the <namespace>:<localname> notation, where <namespace> can be a custom namespace or one of the predefined prefixes “xsd” (http://www.w3.org/2001/XMLSchema) or “SOAP-ENC” (http://schemas.xmlsoap.org/soap/encoding/).
For example:
"http://soapinterop.org/:param1"
"xsd:int"
Request object
The request object is an object literal that specifies the remote procedure name and the parameters to call. The object literal uses the qualified method name of the remote procedure as the key. The value of this key is an object literal in which each key is a parameter of the method, and the value of each key is the value of the corresponding parameter of the method.
For example:
{ "http://soapinterop.org/:echoString":{inputString: "Echo!"} }
When passing parameters to a remote procedure, JavaScript types are bound to SOAP types automatically as listed in the following table.
JavaScript type
SOAP type
Comments
Boolean
xsd:boolean
Number
xsd:float
String
xsd:string
Date
xsd:dateTime
Array
SOAP-ENC:Array
Single-dimension arrays only
All items must have the same data type, which must be Boolean, Number, String or Date
ByteArray
SOAP-ENC:base64
Uses the ByteArray “Base64” codec
Other
Not supported
Causes an exception to be thrown
Instead of providing one of these JavaScript data types, a parameter value can also be represented by a literal object with the following properties:
Property
soapType : String
The SOAP type (as a qualified type name) that will be used for the value when generating the SOAP message; this is useful when a datatype is needed other than the automatic bindings described above
soapValue : String
The value that will be used when generating the SOAP message
The value is passed unescaped (e.g. “<” is not converted to “&lt;”) which means that it can be a raw XML fragment that will be passed on as is
For example, integers are not supported in JavaScript, but an integer parameter to a SOAP method can be constructed as follows:
var iPar = { soapType: "xsd:int", soapValue: "1" };
{ "http://soapinterop.org/:echoInteger": { inputInteger: iPar } }
Header object
The header-object is an object literal that specifies the soap header to be included. The object literal uses the qualified name of the header XML element(s) as the key. The value of this key is encoded like a request-object.
For example:
{ "http://example.org/2001/06/tx:Transaction":5, "http://example.org/2001/06/tx:PaymentOption":10}
will create the following header:
<env:Header xmlns:env="http://www.w3.org/2003/05/soap-envelope" >
<t:Transaction xmlns:t="http://example.org/2001/06/tx">
5
</t:Transaction>
<t: PaymentOption xmlns:t="http://example.org/2001/06/tx">
10
</t: PaymentOption >
</env:Header>
Response object
The function returns an object describing the SOAP Body of the returned message in a manner similar to the request object.
The SOAP types in the result are mapped to JavaScript types as listed in the following table.
SOAP type
JavaScript type
Comments
xsd:boolean
Boolean
xsd:integer
Number
xsd:float
Number
xsd:string
String
xsd:dateTime
Date
SOAP-ENC:Array
Array
All items must have the same data type, which must be boolean, integer, float, string or dateTime
xsd:hexBinary
ByteArray
Uses the ByteArray “Hex” codec
xsd:base64Binary
ByteArray
SOAP-ENC:base64
ByteArray
Other
String
Copies the XML string content without change
Example
var url = <get a URL for this service from http://www.whitemesa.com/interop.htm>;
// Call the echoString SOAP method
var testString = "This is my test string";
var response = SOAP.request( url,
  { "http://soapinterop.org/:echoString": { inputString: testString } },
  "http://soapinterop.org/" );
var result = response["http://soapinterop.org/:echoStringResponse"]["return"];
// Call the echoInteger SOAP method
var testInt = { soapType: "xsd:int", soapValue: "10" };
  { "http://soapinterop.org/:echoInteger": { inputInteger: testInt } },
var result = response["http://soapinterop.org/:echoIntegerResponse"]["return"];
