Pack job
Pack job is a processor that packs a job and its associated metadata for transmission. The result is always a single ZIP file that contains a globally unique identifier to identify it across multiple Switch instances.
Pack job also stamps the internal job ticket of its output with the unique identifier so that confirmations can be matched with the packed data without opening the ZIP file.
See Acknowledged job hand-off for an example of how to use this tool.
Keywords
The keywords for the Pack job element are:
Connections
Pack job allows only a single outgoing connection.
Properties
Property
Name
Include internal metadata
If set to yes, the output archive contains internal job ticket information for the job (including email info, hierarchy info, private data fields, etc.)
Include external metadata
If set to yes, the output archive contains a copy of the external metadata (i.e. all datasets) associated with the job
Embedded metadata is always included since it is part of the job file itself
Compress
If set to yes, the data in the output archive are compressed (the default behavior)
If set to no, the data are stored in the output archive without compression, dramatically reducing processing time; this can be meaningful when speed is more important than size, or when the data won’t compress well anyway (e.g. JPEG images)
Password
The password used for protecting the output archive, or empty if no password-protection should be used
