ProofMaster
This configurator drives PerfectProof ProofMaster. It is a processor that generates a printed proof (as a side-effect of processing) and optionally exports the proofed job (possibly in a different file format and “annotated” with feedback from the proofing process).
Depending on the result of color certification in ProofMaster, the exported job moves along the outgoing success or error data connections. A log file with feedback about the proofing process moves along the corresponding log connections. The incoming job is not retained.
ProofMaster and Switch must be installed in the same local network but not necessarily on the same computer.
Keywords
The keywords for the ProofMaster configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Not provided
Searching from the elements pane
Broadcasts a message on the local network to locate ProofMaster RIPs
Manually locating the executable
Not provided
Connections
This configurator supports any number of outgoing traffic-light connections.
Properties
Property
Name
ProofMaster queue
The name of the ProofMaster queue that should receive incoming jobs
The queue specifies a particular set of proofing options including the target printer
Export as
The format of the exported job; choices are: PDF, PostScript
This overrides the export settings in the ProofMaster queue
Wait for certification
If set to yes, the configurator waits for the results of the color certification performed under ProofMaster’s direction
If set to no, the configurator waits only until the proof has been successfully printed
Timeout after (minutes)
A job is moved to the problem jobs folder if proofing (and possibly certification) has not been completed within this amount of time
