Processing
These preferences configure some aspects of how Switch processes jobs.
Property
Concurrent file transfers
The number of FTP and email file transfers (counting both send and receive) allowed to occur in parallel
Concurrent transfers to the same site
The number of file transfers to the same FTP site allowed to occur in parallel (counting both send and receive)
Automatic means that there is no limit other than the overall maximum number of concurrent file transfers as determined by the previous preference
Concurrent external processes
The number of third-party applications and compress/uncompress processes allowed to run in parallel
Default number of slots for concurrent elements
The number of slots available for scripts and tools working in concurrent mode. By default, this property is set to "1", this will cause a serialized execution mode. Change the number of slots to more than 1 to execute in concurrent mode. Setting this property to "0" means all available slots will be used.
In PowerSwitch, this default value from the preferences can be overruled by
  1. Setting the flow property Allow advanced performance tuning to yes
  2. Changing the element property "number of slots" from default to any other value.
Performance tuning properties and preferences need to be set cautiously because however they are made to speed up processing, unwary use may slow down performance.
Scan input folders every (seconds)
The frequency with which input folders (i.e. the folders without incoming connections) and submit hierarchies are scanned for newly arrived jobs
Scan intermediate folders every (seconds)
The frequency with which intermediate folders (i.e. the folders with incoming connections) are scanned for newly arrived jobs
Note that jobs placed in an intermediate folder by Switch are detected and processed immediately and without waiting for the next scan
Process file only after (seconds)
The time for which newly arrived jobs must be stable before they are processed; to avoid picking up an input job before it has been completely written to disk, Switch ensures that the size of the file (or the total size of a job folder) hasn’t changed for at least this amount of time before processing the job
Reactivate flows upon startup
When starting up, if this property is set to yes, Switch automatically reactivates flows that were active when Switch was last closed; otherwise all flows are inactive after startup
Stop processing if free disk space for application data is less than (Mb)
If the amount of free disk space for application data is lower than the entered amount, processing will stop, avoiding "Disk Full" processing errors.
