Processing results schema
The FTP send and Mail send tools produce a log file with processing results. This log file is carried along the outgoing log connections.
In PowerSwitch this log file can be associated with the job as a metadata dataset by using a "data with log" connection (see the "Carry this type of files" property of traffic-light connections).
Data model and schema
The processing results log file uses the XML data model with a simple schema without namespaces.
The XML document element name is “ProcessingResults”. It contains a sequence of elements with a name and contents as described in the following table. If a data item is not applicable, the corresponding element may be missing.
Element name
Data type
Destination
Text
For FTP, the complete target URL for the job
For Mail, the list of destination email addresses
FlowElementName
Text
The name of the flow element that produced this log file (as displayed in the canvas)
FlowElementType
Text
The type of the flow element that produced this log file (e.g. “FTP send” or “Mail send”)
FlowName
Text
The name of the flow (as displayed in the flows pane) containing the flow element that produced this log file
JobArrivalStamp
Integer
The arrival stamp for the processed job as a signed integer number; a lower arrival stamp indicates a job that arrived in the flow earlier (and vice versa)
Several jobs may have the same arrival stamp, for example when multiple jobs are generated from the same original job
JobByteCount
Integer
The size in bytes of the processed job; if it is a job folder, all files in subfolders are included in the count, recursively
JobExtension
Text
The processed job’s filename extension, or the empty string if there is none
JobFileCount
Integer
The number of files in the processed job, including all files in subfolders, recursively (folders and subfolders themselves do not contribute to the count)
JobFiles
Sequence of “File” elements
A sequence of one or more “File” elements representing the files in the processed job in arbitrary order; each File element has the Text data type and contains the relative path of a file within the job (using a forward slash as path separator)
Folders are NOT represented in this list
JobIsFile
Boolean
True if the processed job is a single file, false otherwise
JobIsFolder
Boolean
True if the processed job is a folder, false otherwise
JobName
Text
The file or folder name for the processed job, including filename extension if present, but excluding the unique filename prefix
JobNameProper
Text
The file or folder name for the processed job excluding filename extension and excluding the unique filename prefix
JobOrigin
Text
An indication of the origin of the processed job before it was injected in the flow; for example, a submit point writes the absolute path of the original job (on the client machine) in this field
JobPath
Text
The absolute file or folder path for the processed job as it resided in the input folder before being processed, including unique filename prefix
JobPriority
Integer
The job priority assigned to the processed job as a signed integer number
JobUniqueNamePrefix
Text
The unique filename prefix used for the processed job, without the underscores; for a job called “_0G63D_myjob.txt” this would be “0G63D”
JobUserName
Text
The user name associated with the processed job, if any
ProcessingEnded
Date
The date-time when the operation was completed (in the ISO 8601 format also used for Switch date variables)
ProcessingStarted
Date
The date-time when the operation started (in the ISO 8601 format also used for Switch date variables)
ServerAddress
Text
The name or IP address of the destination server
ServerLoginName
Text
The user name used to login at the destination server
ServerPort
Integer
The port of the destination server
