Quite Hot Imposing
This configurator drives Quite Hot Imposing. It is a processor that imposes the pages in a single PDF file using a specified imposition schema, generating a single PDF file that contains the imposed flats.
The resulting PDF file flows along the “data” output connections, the log file flows along the “log” output connections.
Keywords
The keywords for the Quite Hot Imposing configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed
Searching from the elements pane
In addition to the above, searches the system program files/applications folder for the application
Manually locating the executable
Select the command line tool that is installed as part of the application
Connections
This configurator supports any number of outgoing traffic-light connections.
Properties
Property
Name
Control file
A control file that contains the instructions for performing the imposition; can be an XML file saved from the Quite Hot Imposing hot folder tool or a previously imposed PDF file
Bleed preference
Selects a preference which can be overridden in the control file; the Bleed optioncontrols what to do in case a page to be imposed contains bleed; choices include:
  • Warn: issue a warning message
  • Use: use the bleed (i.e. use Trim Box)
  • Ignore: ignore the bleed (i.e. use Crop Box)
Flatten preference
Selects a preference which can be overridden in the control file; the Flatten option controls what happens with form fields and annotations in the document; choices include:
  • None: ignore form fields and annotations (i.e. they won’t appear in the imposition).
  • Forms and fields: flatten printable form fields and annotations before performing the imposition
PDF/X preference
Selects a preference which can be overridden in the control file; the PDF/X option controls what happens to the PDF/X status of a file; choices include:
  • Ignore all: ignore PDF/X status of input file
  • Preserve all: preserve PDF/X status of input file (limits some functions -- refer to Quite documentation)
Registration preference
Selects a preference which can be overridden in the control file; the Registration option controls the appearance of registration marks in the result; choices include:
  • All separations: on all separations
  • CMYK: 100% C,M,Y,K
  • Black: black only
Note:
the preferences for Bleed, Flatten, PDF/X and Registration specified with the Quite Hot Imposing hot folder tool are ignored when using Switch.
