Related Adobe InDesign or QuarkXPress jobs are often stored in a single job folder with multiple “main” files at the top level and shared resources (such as images and fonts) in subfolders. The Switch configurators for these applications however expect a single main file in each job folder, so these “multi-job folders” can’t be processed without change.
The “Split multi-job” tool splits a multi-job folder in separate job folders, one for each main file. Each resulting job folder contains a single main file, and a full copy of all resources (in fact, everything from the original job folder except for the other main files).
The keywords for the Split multi-job element are:
Split Multi-job allows only a single outgoing connection.
Name |
Main file type |
The file type or file name extension of the main files. The tool will output a separate job folder for each main file in the incoming job folder. Main files are recognized only if they are located immediately inside the job folder, not in a subfolder |
