This configurator drives StuffIt Deluxe. It is a processor that extracts files from an archive in one of the many formats supported by StuffIt.
The configurator does not support creating new archives through StuffIt.
The keywords for the StuffIt Deluxe configurator are:
Detection mechanism |
Comments |
Automatic detection at startup |
Uses information registered with the operating system when the application is installed |
Searching from the elements pane |
In addition to the above, searches the system program files/applications folder for the application |
Manually locating the executable |
Select the unstuff command line tool that is installed as part of the application On Windows it is called "console_unstuff.exe" and it is located in the StuffIt Deluxeinstallation directory On Mac it is called "unstuff" and it is located in the "Resources" folder inside the StuffIt Setup Assistant bundle |
This configurator supports any number of outgoing traffic-light connections.
Name |
Passwords |
A list of passwords for opening password-protected archives |
Remove redundant folders |
If set to yes, redundant top-level folders are not included in the resulting file hierarchy (see description below) |
