Ultimate Impostrip On Demand
This configurator drives Ultimate Impostrip On Demand. It is a processor that accepts PDF, PS, EPS, TIFF, JPG, BMP and PNG as input files and produces a PDF, PS or JDF file as output.
Keep in mind that the "enable XML input" option of Ultimate Impostrip must be enabled.
Keywords
The keywords for the Ultimate Impostrip On Demand configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed
Searching from the elements pane
In addition to the above, searches the system program files/applications folder for the application
Manually locating the executable
Select the command line tool that is installed as part of the application
Connections
This configurator supports any number of outgoing traffic-light connections.
If the incoming job is an individual file, it is passed to Impostrip On Demand on its own. If the incoming job is a job folder, all files immediately inside the job folder are passed to Impostrip On Demand. Any subfolders and their contents are ignored. Any file in an unsupported format causes the complete job to fail.
Properties
Property
Name
Queue
The name of the processing queue to be used, selected from the list published by Impostrip On Demand Digital.
These settings are created using the standard Impostrip On Demand Digital user interface.
This property is required.
