Ungroup job
Ungroup job is a processor that, in combination with assemble job, provides a way to keep track of files that belong together while they are being processed separately.
Ungroup job injects all files from a job folder into the flow as separate jobs. After these files have been processed through the flow (and possibly were renamed), assemble job can reassemble them into a new job folder with a structure similar to the original one, with provisions for injecting additional files and for dealing with incomplete jobs or orphaned files.
Keywords
The keywords for the Ungroup job element are:
Usage examples
Connections
Ungroup job allows only a single outgoing connection.
Properties
Property
Name
Private data key
The first portion of the private data key used to store the information for reassembling the job later on
Varying this value here and in assemble job allows:
  • Ensuring that a job is reassembled by the intended assembler
  • Nesting ungroup/reassemble operations
Private data
Ungroup job stores the following information in the internal job ticket for each injected job file, for use by assemble job:
Private data key
Stored value
<key>.JobID
The unique name prefix of the incoming parent job
<key>.JobName
The name of the incoming parent job (without prefix)
<key>.NumFiles
The total number of files injected in the flow for this parent job
<key>.FileName
The name of this file as injected in the flow
<key>.FilePath
The relative path of this file within the parent job folder
