XML pickup is a processor that allows associating an arbitrary XML file with a job as metadata. It supports the following pickup mechanisms:
Metadata alongside asset
Metadata in job folder asset
Metadata refers to asset
For more info see Pickup mechanisms.
The keywords for the XML pickup element are:
The metadata source must be a well-formed XML file with any schema. The dataset data model is XML.
XML pickup allows only a single outgoing connection.
Name |
Dataset name |
A name for the set of metadata picked up by this tool; see picking up metadata |
Pickup mode |
The pickup mechanism; one of:
See also Pickup mechanisms |
Additional properties are shown depending on the selected pickup mechanism; see the description of each mechanism for more information.
