XMP pickup is a processor that allows associating an XMP packet with a job as metadata. It supports the following pickup mechanisms:
Metadata embedded in asset (the default location for an XMP packet)
Metadata alongside asset
Metadata in job folder asset
The keywords for the XMP pickup element are:
The metadata source must be an Adobe XMP packet or a standalone XMP file conforming to the Adobe XMP specification dated June 2005. The dataset data model is XMP.
XMP pickup allows only a single outgoing connection.
Name |
Dataset name |
A name for the set of metadata picked up by this tool; see picking up metadata |
Pickup mode |
The pickup mechanism; one of:
Additional properties are shown depending on the selected pickup mechanism; see the description of each mechanism for more information.
The mechanism for embedding XMP packets in a file is also described in detail in the Adobe XMP specification mentioned above.
There are two distinct methods to locate XMP packets embedded in a file:
Scan the complete file for the magic markers at the head and tail of a packet: this works for any file format, but may possibly locate the wrong packet in case a composite document contains multiple packets.
Interpret the file format’s structure to track down the packet: this guarantees that the correct packet has been located and it is usually much faster, but it requires a specific algorithm for each distinct file format.
The XMP pickup tool interprets the file format for a number of supported file formats, and scans the complete file for all other file formats.
For certain supported file formats the values of binary EXIF and IPTC tags can be merged with the embedded XMP packet before it is picked up. See the "Synchronize EXIF/IPTC fields" property for the embedded pickup mechanism.
