XSLT transform
XSLT transform is a processor that performs an XSLT 1.0 transformation on the incoming XML file and produces the resulting XML, HTML or text file.
Refer to the XSLT 1.0 specification and to widely available literature about XSLT for more information.
See also External metadata.
Keywords
The keywords for the XSLT transform element are:
Connections
XSLT transform allows only a single outgoing connection.
Properties
Property
Name
XSLT transform
The XSLT transform to be applied to the incoming XML file; this must be a valid XML document representing an XSLT 1.0 style sheet
Output file type
The type of the transformed output file: XML, JDF, XMP, HTML, Text, Log, or CSV
