Callas pdfToolbox4 Actions
This configurator drives callas pdfToolbox4. It allows to perform several predefined actions, like creating EPS files from the pages of a PDF file.
Refer to Version requirements for third-party applications for on the third-party application required by this configurator.
Keywords
The keywords for the callas pdfToolbox4 Actions configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed (Windows) or checks the default install location (Mac)
Searching from the elements pane
In addition to the above, searches the system program files/applications folder for the application
Manually locating the executable
Select the executable for the command-line version of the application
Connections
This configurator supports any number of outgoing traffic-light connections.
Properties
Property
Name
Action
The action to perform. Based on the selected Action, other parameters can be set.
For more information on each of the available actions, we refer to the callas Toolbox4 reference guide.
