Callas pdfToolbox4 Impose
This configurator drives callas pdfToolbox4. It allows to create an imposition based on sheet templates and runlists, just like the action "Impose" of the callas pdfToolbox4 Plug-In or Standalone.
Keywords
The keywords for the callas pdfToolbox4 Impose configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed (Windows) or checks the default install location (Mac)
Searching from the elements pane
In addition to the above, searches the system program files/applications folder for the application
Manually locating the executable
Select the executable for the command-line version of the application
Connections
This configurator supports any number of outgoing traffic-light connections.
Properties
Property
Name
Old style config folders
Set this option to "yes" if you want to use old style configuration folders (pdfToolbox before 4.4), and select the configuration folders.
Runlist configuration
The Runlist configuration to be used for the imposition. When choosing "Select from library", you can select a configuration from callas pdfToolbox Server 4 installation folder.
SheetConfig settings
The SheetConfig settings to be used for the imposition. When choosing "Select from library", you can select a configuration from callas pdfToolbox Server 4 installation folder.
Preprocess
Set this option to yes to perform a PDF conversion based on .kfpx profiles prior to imposition.
Select your desired profile as explained in the pdfToolbox4 Profiles configurator.
Callas pdfToolbox4 Server is delivered with a set of predefined sheet templates. The setup of new templates is described in the chapter "Use of imposition cfgs" in the callas pdfToolbox4 Reference guide.
The callas pdfToolbox4 Impose configurator supports both single PDF files and folders. If a folder is passed to this configurator all PDF files inside this folder are merged prior to imposition
Note:
Preprocessing is omitted when working with folders.
