Callas pdfToolbox4 Profiles
This configurator drives callas pdfToolbox4. It allows to check and/or modify PDF files using pdfToolbox 4 Profiles. These can created and/or adapted with the pdfToolbox4 Plug-In or Standalone version. For more information we refer to the section "Use of kfpx profiles" in the Callas pdfToolboxF Reference guide.
Keywords
The keywords for the callas pdfToolbox4 Profiles configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed (Windows) or checks the default install location (Mac)
Searching from the elements pane
In addition to the above, searches the system program files/applications folder for the application
Manually locating the executable
Select the executable for the command-line version of the application
Connections
This configurator supports any number of outgoing traffic-light connections.
Properties
Property
Name
Profile Group
The Group from which to select a Profile. Selecting a group is necessary to select a Profile using "Choose from Library"
Profile
Select the calllas pdfToolbox 4 Profile to be used. When using "Choose from Library", only the profiles available in the selected Profile Group will be listed.
Maximum hits per page
Defines the maximum amount of hits to be checked and reported per page
Maximum hits per document
Defines the maximum amount of documents to be checked and reported per page
Report Type
The format of the Report to be created. Choices include:
  • XML: an XML file that formally conforms to the XML schema installed with pdfToolbox Server 4
  • XSLT: an XSLT file that transforms the XSL report into another format like HTML or TXT
  • PDF Mask: the original PDF file with semi-transparent marks inserted on new layers to visually indicate preflight problems, combined with PDF comments
  • PDF comments: the original PDF file with comments inserted to indicate preflight problems
  • PDF Layer: the original PDF file with certain text, graphics and image objects separated on different layers; this is more than strictly a report format
  • Inventory: PDF document that provides statistics. Refer to the pdfInspektor manual for more information
Create Report If
Only generate a report under the following circumstances:
  • ALWAYS: always
  • ERROR: if at least one problem with severity ’Error’ was found
  • WARNING: if at least one problem with severity ’Warning’ was found
  • INFO: if at least one problem with severity ’Info’ was found
  • HIT: if any problem was found
  • NOHIT: if no problem was found
  • ERROR, WARNING: if at least one problem with severity ’Error’ or ’Warning’ was found
  • INFO, WARNING: if at least one problem with severity ’Info’ or ’Warning’ was found
Overview Page
Select Yes if you want to add an overview page to the report
Report Suffix
Define a suffix to be added to the resulting file name after a trailing underscore ( _ ). Leave empty for no suffix.
Additional Report Type
Allows to generate a secundary report
Report Language
The language to be used in the report
Embed XML Report as Metadata
Create an XML Report, and embed it as Metadata, using the defined Dataset name
Disable Fixups
If set to yes, all fixups defined in the pdfToolbox 4 Profile will be disabled.
Uncompress images
If set to "Yes", this option will uncompress images when checking. By default this option should be set to "No", since it is time consuming, and not needed for most checks. It might be needed in some cases, for example if you need to know wether pixels of an image defined in CMYK are just using the Black colorant when checking for grayscale images.
Define variables for dym. profiles
Allows to define variables and values to be used in dynamic pdfToolbox 4 Profiles. Please see the log after activating this option to see the possible variables for the selected profile.
Limit pagerange for checking
Limit the checking to a specific page range of the documents
The setup of new configuration files in callas pdfToolbox 4 is described in the chapter "Use of color conversion" in the "callas pdfToolbox 4 Reference".
