DMP FLO Suite
This configurator allows to send and retrieve files to DMP FLO suite, a Web2Print application
As the DMP configurator is connecting to the FLO Suite application through an internet connection, there are no licensing requirements.
Note that the FLO Suite can only handle individual files, except for the Online Proofing command, which can handle job folders.
Keywords
The keywords for the DMP FLO Suite configurator are:
Detecting the application
As this configurator is connecting to the FLO Suite application through an internet connection, there is no application to discover
Connections
This configurator supports any number of outgoing traffic-light connections.
Configurator properties file
The configurator uses a file named Flo_servers.txt, which should be in /Library/Application Support/SwitchScripts/DMP (Mac), C:\Documents and Settings\All Users\Application Data\SwitchScripts\DMP (Windows) or C:\ProgramData\SwicthScripts\DMP (Windows 7 and Vista). This file should contain the server name and address, and the account’s user name and password.
Entering a Server name in the property (or selecting it using Select from library) will search the flo_servers.txt file for the server and use the corresponding server address.
Entering a Client ID in the properties (or selecting it using Select from library) will search the flo_servers.txt file for the server and use the corresponding user name and password.
Properties
Property
Name
Server
The DMP FLO Suite server to connect to.
Select from library allows to select a server name from the configurator properties file (see above)
ClientID
ID of the client in FLO where the job should be added in the queue. You can find this under the "Client" tab in the FLO interface.
Select from library allows to select a Client ID from the configurator properties file (see above)
Command Type
The type of command to execute.
This can be Online Checkpoint, Create Asset, Create Artwork, Script. Other properties below depend on the selected command.
Job Description
Only available when Command Type is set to Online Checkpoint.
Description for the job, which can be used by the DMP FLO Suite integrator in the online interface
Queue Name
Name of the queue for the FLO server. E.g.: "Incoming Jobs"
Queue Description
Description of the queue. Used by custom scripts on the server
Success Description
Description for the "Success" option in the online interface
Warning Description
Description for the "Warning" option in the interface
Error Description
Description for the "Error" option in the interface
Custom Info
Additional information for the FLO interface. This can be used for integrators for things like security.
Orphan Timeout
The time delay after which a checkpoint is considered orphaned
assetFloDirectory
Only available when Command Type is set to Create Asset.
The location of the uploaded file in assetFLO, eg. Directory1\Subdirectory
Replace Files
Only available when Command Type is set to Create Asset or Create Artwork.
Overwrite existing files with the same name when set to "Yes", or create a new file.
artworkFlo Directory
Only available when Command Type is set to Create Artwork.
The location of the uploaded file in artworkFLO (eg. Directory1\Subdirectory)
Command
Only available when Command Type is set to Script.
Name of the script to execute. You should get this name from the DMP FLO Suite integrator.
Arguments
Optional additional arguments for the script. You should get these from the DMP FLO Suite integrator
