This configurator allows to send files to the Elvis Asset Management System.
As the Elvis configurator is connecting to the Elvis application through a SOAP server, there are no licensing requirements.
Note that the Elvis Send configurator can only handle individual files. Job folders will fail.
The keywords for the dutchsoftware Elvis Send configurator are:
As this configurator is connecting to the Elvis application through a SOAP server, there is no application to discover
This configurator doesn’t support outgoing connections.
Name |
Server URL |
The Elvis server url as mentioned on the Elvis client install page |
User name |
Elvis user name. The user must have sufficient permissions. |
Password |
Elvis user password |
Action |
Select the action to perform:
Folder path |
The destination folder in Elvis. When using with action ’Create Variation’, take care on the setting of ’Append hierarchy info’, as the hierarchy will be appended to the path specified here. |
Append hierarchy info |
Append job hierarchy info to ’Folder path’. If the Folder path is empty, the hierarchy info attached to the job will define the complete destination path in Elvis. |
Field to set |
The Metadata field to set after the asset has been uploaded. This must be a valid Elvis metadata field name. |
Value to set |
Value to set in the chosen metadata field after the asset has been uploaded. |
Dataset name |
Name of the dataset where the asset’s metadata is stored. |
