dutchsoftware Elvis Receive
This configurator allows to retrieve files from the Elvis Asset Management System.
As the Elvis configurator is connecting to the Elvis application through a SOAP server, there are no licensing requirements.
Detecting the application
As this configurator is connecting to the Elvis application through a SOAP server, there is no application to discover
Keywords
The keywords for the dutchsoftware Elvis Receive configurator are:
Connections
This configurator doesn’t support incoming connections. It allows a single outgoing connection.
Properties
Property
Name
Server URL
The Elvis server url as mentioned on the Elvis client install page
User name
Elvis user name. The user must have sufficient permissions.
Password
Elvis user password
Scan every (minutes)
Number of minutes between searches
Batch size
Maximum number of files to download per batch.
Query
Additional Elvis query to limit the returned results. If left blank, all assets will be found.
Example queries:
  • status:Final: find all assets with status ’Final’
  • ancestorPaths:/Demo/Zone/Images: Find all assets in subfolders of /Demo/Zone/Images
  • rating:[4 to 6]: Find all assets with a rating between 4 and 6
Field to set
The Metadata field to set after the asset has been downloaded. For example define a custom field in the Elvis "customassetinfo.xml" called "cf_pickedUpBySwitch.
This must be a valid Elvis metadata field name.
When used in combination with the "Exclude if already set" propery, you can prevent an asset to be processed twice.
Value to set
Value to set in the chosen metadata field after the asset has been downloaded.
Exclude assets from download
Exclude assets from the query that already have a value for the "Field to set".
Dataset name
Name of the dataset where the asset’s metadata will be stored.
Attach hierarchy info
Will attach folder path from Elvis as hierarchy info.
