ICS RD Report
This configurator allows to retrieve feedback from ICS Remote Director, and use the feedback or signoff status to route the files further on in the flow..
Keywords
The keywords for the ICS RD Report configurator are:
Detecting the application
This configurator implements the following mechanisms to detect the presence of the corresponding third-party application. This entails that the ICS RD configurator is able to find the ICS RD CL API. See Detecting third-party applications for more information.
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed (Windows) or checks the default install location (Mac)
Searching from the elements pane
In addition to the above, searches the system program files/applications folder for the application
Manually locating the executable
Browse to the correct folder and select the icsiproofmgr file
Connections
This configurator allows multiple traffic light connection.
Properties
Property
Name
Customer
Name of the customer-level folder that will have Jobs inside
Job
Name of the Job-level folder that will have Proofs inside
Proof name
Name of the proof to create
Finish proof
Set the proof to finished or not.
Delete proof
Delete the proof from the server
Timeout
Set a time in which the proof has to be reviewed before failing the proof. In this case, you can define this Orphan timeout in hours.
Username
Seat username. When set to default, the user name must be defined in the Preferences file
Password
Seat password. When set to default, the password must be defined in the Preferences file
Preferences file
If the properties "Username" or "Password" are set to default, their value must be specified in a preferences file.
An example file is installed and can be found in:
  • Mac: /Library/ApplicationSupport/SwitchScripts/ICS
  • Windows: C:\Documents and Settings\All Users\Application Data\SwitchScripts\ICS
  • Windows 7 or Vista: C:\ProgramData\SwitchScripts\ICS
(The same preferences file can be used for both Submit and Report configurator)
