This configurator allows to make online proofs using ICS Remote Director, and to invite people to the proof.
The keywords for the ICS RD Submit configurator are:
This configurator implements the following mechanisms to detect the presence of the corresponding third-party application. This entails that the ICS RD configurator is able to find the ICS RD CL API. See Detecting third-party applications for more information.
Detection mechanism |
Comments |
Automatic detection at startup |
Uses information registered with the operating system when the application is installed (Windows) or checks the default install location (Mac) |
Searching from the elements pane |
In addition to the above, searches the system program files/applications folder for the application |
Manually locating the executable |
Browse to the correct folder and select the icsimageconvert file |
This configurator allows multiple traffic light connection.
Name |
Customer |
Name of the customer-level folder that will have Jobs inside |
Job |
Name of the Job-level folder that will have Proofs inside |
Proof name |
Name of the proof to create |
Invitees |
List of seat user names who are invited to this proof |
Invitees permissions |
To give an invitee several permissions, permissions are separated with a plus sign (+). A special permission called "all" is shorthand for all permissions combined and is equivalent to inviteseats+addimages+signoff+colormgmt+print. |
Create seat for invitee |
Create a new seat before submitting a proof. If set to yes, information about the new user (name, address, company, ...) can be added.
Profile handling |
Specifies whether to use an embedded profile or not.
Image Server |
Name of the image server. When set to default, the name of the server must be defined in the Preferences file |
Username |
Seat username. When set to default, the user name must be defined in the Preferences file |
Password |
Seat password. When set to default, the password must be defined in the Preferences file |
Preferences file |
Properties that are set to default must be specified in a preferences file. This preferences file can also be used to specify additional parameters. An example file is installed and can be found in:
