This configurator drives Microsoft Word. It is a processor that allows saving a Word file to PDF. In addition it supports executing a macro on the file, and allows saving in a number of common text formats.
The Microsoft Word configurator supports incoming job folders in addition to individual files. In case of a job folder, the configurator expects that the folder contains a single Microsoft Word file on its topmost level, and that all resources referred to from within the Microsoft Word file reside in the job folder or in one of its (nested) subfolders.
The keywords for the Microsoft Word configurator are:
Detection mechanism |
Comments |
Automatic detection at startup |
Uses information registered with the operating system when the application is installed |
Searching from the elements pane |
Same as above |
Manually locating the executable |
Select the application |
This configurator allows multiple traffic light outgoing connection.
Name |
Command |
The command to be performed; i.e. one of the following options:
Save as |
The method or format to save the job: PDF, PDF/A, XPS, rtf, txt or html |
Re-link all graphics |
If set to yes, the configurator instructs Microsoft Word to re-link all graphics before processing or outputting the Word job |
Use fonts in document |
If set to yes, fonts included in a processed Microsoft Word document or documents folder are used while processing or outputting the Microsoft Word job |
Fail jobs with unavailable fonts |
If set to yes, the configurator fails any jobs that use one or more fonts which can't be found/activated; i.e. these jobs are moved to the problem jobs folder If set to no, the configurator doesn’t test for unavailable fonts |
Fail jobs with unavailable images |
If set to yes, the configurator fails any jobs that use one or more images which can't be found; i.e. these jobs are moved to the problem jobs folder If set to no, the configurator doesn’t test for unavailable images |
PDF/A and XPS output are only available in Microsoft Word on Windows.
PDF, PDF/A and XPS output on Microsoft Word on Windows, require a plug-in in Microsoft Word. If the plug-in is missing, the job will fail.
