Qoppa jPDFPrint
This configurator drives Qoppa jPDFPrint, which allows to print PDF documents without any user intervention.
Keywords
The keywords for the Qoppa jPDFPrint configurator are:
Detecting the application
This configurator implements the following mechanisms to detect the presence of the corresponding third-party application. SeeDetecting third-party applications for more information.
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed
Searching from the elements pane
In addition to the above, searches the system program files/applications folder for the application
Manually locating the executable
Select the application
Connections
This configurator allows an optional outgoing connection.
Properties
Property
Name
Printer
The Printer to send the files to
Shrink page
Shrink to printable area
Expand page
Expand to printable area
Center
Center the PDF on the page
Auto-Rotate
Rotate the PDF for best fit on the page
Password
Password to open the PDF when the file is encrypted
