This configurator drives Qoppa jPDFSecure, which allows to change the security settings on PDF Documents. It can encrypt and decrypt PDF documents as well as set permissions..
The keywords for the Qoppa jPDFSecure configurator are:
Detection mechanism |
Comments |
Automatic detection at startup |
Uses information registered with the operating system when the application is installed |
Searching from the elements pane |
In addition to the above, searches the system program files/applications folder for the application |
Manually locating the executable |
Select the application |
This configurator allows only a single outgoing connection.
Name |
Action |
Select the security action to perform (set, modify or clear security) |
Set Open Password |
Set the password to open the document. |
Set Permissions Password |
Set password to grand or deny permissions |
Allow Printing |
Allow to print the document. If set, you can also set "Allow printing in high resolution". |
Allow filling from Fields and Signing |
Allow filling in fields, or sign them |
Allow Document Assembly |
Allow to assemble the document, insert, ortate or delete pages and create thumbnails or set bookmarks |
Allow Extraction for Accessibility |
Allow to extract text or graphics. |
Current Open Password |
If Action is "clear security", enter the current password if already set |
Current Permission Password |
If action is "clear security", enter the current Permissions password if already set. |
