Remount Volumes
Remount Volumes is only available when Switch is running on Mac OS X.
It contains one single preference: a list of volume paths with corresponding user name and password.
These volumes will be automatically (re)mounted, using the specified user name and password.
The list of volumes to be remounted, shows the Volume path, the User name and Password.
When closing the list editor, only volumes with a defined user name will be kept.
Show volume paths used by active flows
When editing the Volume list, the Show volume paths used by active flows can be used to list all volume paths currently in use by active flows at the end of the list. If the volume path contains a user name, this will be entered in the User name field. The password is NOT added automatically.
When turning the option off, all volume paths with an empty user name will be removed from the list.
