This configurator allows uploading files to the WoodWing Enterprise system.
If the incoming job is a job folder, the job will fail. If the incoming job is an individual file, it is downloaded if it matches the criteria
The keywords for the WoodWing Enterprise Upload configurator are:
The configurator needs to be pointed to the SOAP server. There is no need to have additional applications installed on the computer running Switch, so no application detection is necessary.
This configurator allows only a single outgoing connection.
Name |
Server |
The configuration template to be used. This property is requred |
User Name |
The User Name for the WoodWing system |
Password |
The password to connect to the WoodWing system |
Brand / Category |
The Brand and Category for the uploaded job in WoodWing Enterprise |
Strip unique name |
If set to yes, the unique name prefix will be stripped from the file name. If set to name, the full file name is used. |
