Loading the activation response file
Once you are back at the machine running Enfocus Switch, do the following to load the activation response file:
  1. Open the Activate License Wizard (on PC) or the Activate License Assistant (on Mac) by either:
    • going to the Trial tab of the About Enfocus Switch window and clicking Activate,
    • going to Help > License > Activate .
  2. Click Next / Continue in the first screen of the Activate License Wizard/Assistant dialog box.
  3. Select Off-line activation again and click Next / Continue.
  4. Select Step 2: Load an activation response and click Next / Continue.
  5. Browse to the response file you copied from the machine with full Internet access and click Next / Continue.
    Attention: Select the response file you downloaded from the website (response.xml) and NOT the activation request file you uploaded.
    A status bar will appear while the system processes the response file, and then a message will appear that the activation completed successfully and that you can now use the product(s) on your computer.
  6. Click Finish / Done.
    The product and its license will appear in the License tab of the About Enfocus Switch window (previously called Trial tab).
