Archive hierarchy is a consumer that creates a nested hierarchy with one or more levels of subfolders. It is used to archive jobs into a structured hierarchy at the end of a flow. The resulting jobs are to be consumed (and removed) by an external process. The backing folder (on disk) for an archive hierarchy should typically be user-managed.
It is not allowed for an external process or a user to place files into an archive hierarchy.
An archive hierarchy uses the hierarchy location path stored in a job's internal job ticket to determine where the job should be stored, up to the nesting level specified for the archive hierarchy. Any superfluous segments in a location path are ignored. Subfolders are created automatically.
See Using hierarchy info for more details.
The keywords for the Archive hierarchy element are:
Archive hierarchy does not allow outgoing connections
Name |
Path |
The path of the archive hierarchy's backing folder on disk, or "auto-managed" |
Subfolder levels |
The number of nested subfolder levels in the archived structure; see also the description on subfolders earlier. |
Strip unique name |
If set to yes, the unique name prefix added to the filename by Switch is removed before placing the job in the archive hierarchy; the default is to strip the prefixes from jobs deposited in an archive hierarchy - leaving the prefixes in place avoids overwriting a previously deposited job with the same name |
Duplicates |
Determines what happens when "Strip unique name" is set to yes and a job arrives with the same name and location as a job already residing in the hierarchy:
